FIS - LINK - Can Box Converter for Red Dot Matrix FIS and New BT Modules - Druckversion +- ScIROCco Forum - Das erste Forum zum neuen VW Scirocco 3 (http://www.iroc-forum.de) +-- Forum: - Scirocco 3 (/forumdisplay.php?fid=4) +--- Forum: Car Hifi (/forumdisplay.php?fid=11) +--- Thema: FIS - LINK - Can Box Converter for Red Dot Matrix FIS and New BT Modules (/showthread.php?tid=28147) |
FIS - LINK - Can Box Converter for Red Dot Matrix FIS and New BT Modules - boschinger - 25.06.2013 14:45 Hallo, es gibt bei carsystems.eu eine Box, die zwischen das Gateway geschaltet wird und die es ermöglicht die neuen FSE-Boxen, die eigentlich nur an der weissen MFA+ laufen, nun auch mit der roten MFA+ nutzbar zu machen. FIS - LINK - Can Box Converter for Red Dot Matrix FIS and New BT Modules roduct description Plug7Play Can Box Converter for Red Dot Matrix FIS and New BT Modules Make visible the telephone menu 7P6 or 3C8 BT modules on red dot matrix FIS Support also A2DP Music Stream , Phone Book and many other Works with Basic or Premium BT Handsfree units f.ex 7P6035730 all index , 3C8035730 all index , and all models up to this date. Another extra function is that solve battery drain issues with newest RNS-510 Firmwares (from 26xx) in cars equipped with gateways prior to index K (not necessary to change gateway to avoid battery drain) Compatible vehicles - Volkswagen Golf V (1K) - Volkswagen Jetta (1K) - Volkswagen Caddy (2K) - Volkswagen Tiguan (5N) - Volkswagen Touran (1T) - Volkswagen EOS (1F) - Volkswagen Passat (3C) - Volkswagen Scirocco (1K) - Skoda Octavia (1Z) - Seat Altea - Seat Leon Scope of delivery : FIS Box Plug&Play Cable Update Cable Kostenpunkt : 120 Euro plus Versand |
